I don't think that Duplicolor makes 1200* paint, only 500*. How did you originally paint your cross braces? Did you do any prep work at all before you painted them because if you didn't that's probably the reason why the paint is cracking. If you want to get better results this time, strip off as much of the old paint as you can, lay down some primer and wet sand in between each layer to make it smooth, paint then clear coat. If you want results that will last you forever, powdercoating ftw.
