trunk space i dont care about i just want to design a box i dont need to build in the trunk so it can be removed and coated in the summer. so im thinking im going to fire them up and make each sub its own box the only part im undecided with is the port. i have a design i can pm you and see if there is something i can improve on
Last Q, is there a quick way to convert those measuments to fit a 12" sub.??
which measurements? i could prolly figure it out
also if you mean the vent just tell what 12's and ill figure it out the difference is going to be small between this 15box and a 12 version
I forgot in your OP that you're making this box for a 15" sub, I'm looking for a new 12" (i have a simple Sony xplod right now (college budget)) and was looking to make the box before hand. If you dont want to sent specific measurement, would I be safe just knocking off an inch for the box and a little less than an inch for the vent opening?
Sorry where would the port be facing?
It also shouldnt be that close to the bottom if you're going to lay it down as pictured. It would lower your flowing capabilities.
For slot ports I'm not sure but for tubs its the diameter of the port.
I'd venture to guesstimate the height of the port.
Taking a router to the corners of the port would help with flow as well.
Have you decided on a driver yet? I could run some sims to find out how close you are to the limits of port flow.
i dont have anything crazy the subs that im moving from my old vehicle to my new one are alpine type-r 15's swr-1522d, as far as power it will be the same as my old vehicle about 1300watts rms
oh and i forgot if you could check that out it would be great with the current design i think i only have about half an inch more i could open it up before it gets too long or i can take the tune from 32 to 35 according to bbp 6 max air veloicity for that box right now is 25m/s
25 m/s is good.
27 is max IIRC. 25 being ideal.
Still dont like the idea of firing into the trunk though.
I think you should pull the rear 6x9's and 4's if you have 'em, if not, just pop out the pre-cut insulation in the rear deck and install a bose rear deck lid.
Then have the ports sealed to those holes.
