I have KR
I bet your power steering went or is going out and you have a bad upstream O2.
I see that the picture you have is not an 04. Is your 04 with mod list what you have now?
my power steering went out on me yesterday completely!! my picture is my 99 GTP I sold, my mod list is my 04 I drive daily. How'd you know my steering went out, besides reading my posts?!?
lol well can u hear any knocking cuz if u have a chipped piston im sure youd hear it also next time u change your oil check for any metal shavings
I bet if you replace the upstream O2 you will be good to go. I would also do a once over of everything like the plus and ect.. Then I would still have someone tune/scan your car and not just for codes
I knew your pump would take a crap on you because of what you described. You probably had a bad pump already but the high RPMs from going 120mph just helped it along faster.
Yeah im probably gonna pick up a used one for $30, could you point me in the right direction of where the upstrearm 02 is? Im not the best mechanic especially for having a modded car!:th_sick2:
Also - I do know the o2's (or one) is in the exhaust -- tried looking for it once and couldnt. Im missing my passenger side muffler completely.
Thanks in advance!:th_thumb-up:
Upstream O2 sensor is in the rear manifold on the car. I have TOGs so I do mine from under the car but I am not sure about Pace Setters.
It does make some sense about the O2 but I would also check to make sure you have all the plug wires on tight and in the correct order. I would also make sure you didn't crack any of the porcelain on the plug putting them in.
one of the dang plugs in the back keeps breaking porcelain everytime I pull it out, i believe my headers are in the way even when I pull the motor forward so im not putting it in the right way I guess... I would tighten it in just a little and to get it back out was a dam job! It acted like I had it as tight as possible when I really didnt, so when I would finally get it out the top porcelain part would be cracked... ( happened 3 times in the same spot ) getting tired of messin with the damn thing.
