So the down button on my hud switch doesn't work, not sure how to take it out and fix it! I would love to use it!
Sent from my SAMSUNG-SGH-I337 using Tapatalk
What's second I have p r n d m on my thing.Take out the 2 bolts on each side of the console.
Put the gear selector into 2nd, then remove the screw from the shift knob, and take off the shift knob.
Pull up on the console from the back to disengage it from the hold downs. Then ull it rearward slightly until you see the electrical connector at the front of the console/under the IP.
Disconnect the wiring harness at the front of the console/under the IP.
Remove the console from the vehicle.
Disconnect the electrical connector from the HUD switch.
Remove the HUD switch from the back of the console.
Installation is reverse order.
Not sure about how to open the switch and fix it, but a new switch is about $20, so just replace it.
And also where is the two bolts?Take out the 2 bolts on each side of the console.
No I have a 04 gtp with paddle shifters that's why it only has PRNDM down the counsel.Are you working on a 97-03 Grand Prix? If so, the HUD switch is on dash not console. Carefully grip and pull out the instrument panel bezel (like you're gonna put a radio in, that big trim piece). It just pulls off and snaps back in. Nothing is connected to it except the fog lamp wires. Unplug those and remove, or just work around the loosened bezel to remove two screws that hold the HUD switch to the dash. Try that.
Sorry should have said that.That would be good to know up front. But I wondered about only having M. Could have been a Ford for all I knew.
Thanks! So how do I get this one out by chance?No worries, and welcome to GPF.
