INFORMATION How to tint headlights and taillights
I took a good amount of time on the both sets that I did and they turned out good. I think if you take your time and do it right they will be fine. I used to work with a kid that got pulled over for his and asked how he tinted them and he said that he put on like 5 coats of VHT and did not wetsand or use clearcoats. They just looked like someone had taken a flat black spray paint to them. They had very poor output too. So don't do that. lol
Would a normal tint shop do a good job? And how dark
Sent from my pager using Morse code. ... .. ... ....
How much tint u recommend? 50%
I cannot vouch for what you should do with the headlights but for the tails if you use VHT do a light coat and then a second coat and that should be plenty of VHT. Itll be enough to notice but it wont be overdone. I just followed a write-up on here about how to do it and I think it involved wetsanding between each coat and then applying multiple coats of clear and wetsanding I believe.
Not sure what a tint shop would do but they would probably work with you and get an idea of what you are going for.
What kinda paint and clear? Wet sand in between?
they mix it, not you. They will use a spray gun, so better to go to an actual body shop. Not a tint shop.
OK that makes more since. Theres is a really good body shop I'll call em later and see. If not I may try the tint on that sight
I will not lie, my tails are pretty dark.
But thank the heavens the GPs were blessed with a third brake light...
I'm gonna have my headlights tinted professionally at a local body shop. But before I tint them I want to upgrade the lights with some good HID's. What's the best and easiest way to do this. And I don't have an oven to bake my headlights in.
