Will5600
i was looking into getting a oil pressure gauge and wasnt sure how i would install it Prosport Gauges Oil Pressure Gauge 52mmthis is the one i was looking at
you have to run a wire from the oil pressure sending unit, that screws into the oil pump housing near the passenger rear of the engine bay under the car, and back into the cabin for the gauge. the sending unit can either take the place of the low oil pressure sensor or you can use a brass T to use both.
, the oil pressure light comes on at like 5 psi, which is too late anyway.
