How to disable DRL
Thanks, hmm says it may work on older models, wonder if anyone has tried it on on an 02.
EDIT: Oh nevermind, read the thread a bit more and one of the comments said for 97-03 cars to just "pull out the plug that goes into the heatsink behind driverside dash.".
Dont have my manual, just went ahead and pulled out the plug from the driverside dash. No more DRL :)
I'm pretty sure if you look at the label on the back of the fuse door or on the block itself, it should say DRL right on the fuse.
Depends on the year. Some '01+ cars you can't just pull the fuse.
When I pull the fuse, the DRL diode buzzes. If I unplug the DRL diode and remove the fuse, the DRL's don't work, plus the "auto" on" function stops working also. So, I just have the DRL diode unplugged. If you don't want the "auto on" to work, you need to unplug the DRL control module. I have the headlight wire removed from the plug of the module, so just the park lights "auto on".
Here are some visuals:
http://chrisb.users.superford.org/G...Light_Flash/Alarm_Light_Flash.html#MAY27-2015
