You did crack before you posted..... tell us something we didn't already know.
You're fine, I wasn't saying anything to you.I don't care. I say what I did. You do what you want. Simple.
Where is this check valve on the vehicle?Check ball "feed/supply" fitting
I ran the hot fluid into the cooler, then into the stock cooler then into the trans
I've been doing a lot of research on this topic. I found this info and thought it might be usefull......From what I've read, that's backwards. You are reheating the fluid at that point. It should go Trans->stock cooler->external cooler->Trans. That way the coolest fluid goes back into the transmission.
Why did you delete your post? I was going to ask for pics of your install.
Easy.Because I can't get the pic link to function properly.
