CrazyGuy03
There is not one way to do it , but there is one way for each person - says unknown
Sorry but that is just ignorant. The GXPs bassically need a trans cooler to survive under abuse in stock form and anyone making any kind of power with an aftermarket torque converter needs one. I didn't have one of my Billet 3000 stall and the trans jumped to 260 in one pull. If done properly with hoseclamps and the right size barbs it will not leak.I wouldn't put anything or disturb anything in between the trans and the radiator line, as that is somewhat of a pressure line and I've seen and heard many issues, leaks, lines popping off, etc...and that goes for more than just these 3800 powered cars. Personally I wouldn't ever put a trans cooler in these cars, however...if a person would choose too, it's safer to insert it after the radiator, before the return side of the trans.
Why not?Personally I wouldn't ever put a trans cooler in these cars,
Why not?
Just because a bunch of people did improper installs is not a valid reason to me. Thought there might be more to it.He gave his reasons lol
I ran the hot fluid into the cooler, then into the stock cooler then into the trans
Sent from my VS986 using Tapatalk
