Stock L67, no more than a 75 shot, wet or dry.
It can take more, but you WILL loose the tops of your pistons a some point.
Reason being:
These engines are made to be fuel efficient, not to handle nitrous at the drag strip.
The piston ring gap is very tight when the engine reaches operating temperatures, this is why they did this, so they are efficient and meet and exceed EPA guidelines.
You can run nitrous, safely. Wet or dry. (I run dry)
50 shot you can hardly feel, 75 will tuck you back in the seat a little more.
Adding nitrous is like adding fuel to the fire, the engine will run hotter, heat makes parts expand, the piston rings expand past their limit, and pop goes the top of your piston(s).
When I built my engine, I built it to run on a VERY healthy shot of nitrous. Increasing the ring gap, to choosing the right cam all played a role. My limitation is the heads, as too much boost, and N2O, they will "float" and then I will start loosing head gaskets. Not enough "clamping force" on these heads to the block like other engines have.
~F~
