how many bolts?
the only one that you "won't see" is the one that goes in on the backside of the motor from the passenger side.
is there on on the bottom right near the manifold from the first pic? or is that just a dowel location? if there was a bolt there it looks as thou it would bolt into the transmission as in the 2nd pic it woul be the one closest to the long part where the axle to the passenger side wheel would go(right under the tie wrap)
if your leaving the engine in the car, this pic shows the backwards bolt. you need a long extension to reach it from the pass side wheel well. air tools are optional.
