ericspecullaas
why? .....the temp gauge is faulty
Well, we know an engine doesn't overheat that fast, unless completely dry... So the assumptions must be made.
1. There is coolant in the system.
2. The thermostat is working correctly.
3. The water pump is circulating the coolant.
4. Air has been removed from the system.
Is all it takes... So if your temp gauge is climbing immediately like that and the other assumptions are not probed false then you just move on to the next hypothesis.
1. The temp sensor is bad.
2. The wiring is bad (sensor to pcm).
None of this means the engine is actually running hot, but if sensor is reporting it as such, will cause the pcm to put engine into limp mode.
Check the sensors, I'd have to look it up to check resistance value. And replacing it doesn't mean the second one is good either... Lol. But shotgunning parts at a problem sucks too. Are you sure when you broke the sensor, you didn't do damage to the wiring at the plug/wire which attaches to the sensor? Can't be running hot like that unless you left something in there blocking coolant flow. When you filled coolant and started engine with radiator cap open (thermostat removed), water was moving?
could you actually see the coolant circulating ?The old one was thrown away. Just removed the new one and got a replacement, same results on this one too...
Any other good ideas? Removing the thermostat and running it without one it did the same thing.
Where should I be checking for movement?
open rad cap, rev engine. you'll see the coolant move, maybe even drop then come back up when you let off the rpm's.
It was the crappy BWD sensor'S. The guy at advance used an ohm meter to get a base read and then hit it with a lighter to see how it changed, he then looked up an ohm graph for it and sure enough both BWD sensors I had were reading in celcius.
fixed it. ...see what you get for doubting scottydoggs ? :th_biggrin2:
