Gasnmyveins
Well, my engine appears to be shot, so I'm getting one to replace it. I can get an L67 with around 110,000 for maybe $1200 or $1000, or I can get the l26 with around 75,000 miles, for $600 to $800. The engines have a 90 day warranty, so I wouldn't swap my top end over until my vacation time this summer. Time shouldn't be an issue. My question is, how did your swap go? What problems did you encounter? Do most swaps go fairly smoothly, or do they tend to blow up in peoples faces?
I'd rather get the engine that was designed for boost from the beginning, but I have 2 reasons for considering the swap. The N/A engine has +- 50,000 fewer miles, and has never been subjected to boost. Or boost with a vacuum leak or dirty injectors or a bad IAC or a bad lim or 87 octane, and on and on. It's also quite a bit cheaper, and I can get the parts I need over a few months. That always helps. Also, I'd end up changing the lim anyhow, so either engine is coming apart to a certain extent.
So, back to my question. How did your swap go?
Thanks, Gas.
Thanks, Gas.
