MuzikFreak
The car was bought jus a few months ago and everything seem good. Then it started to smoke a little out the exhaust on start up. Didn't think much of it because I thought valve seals. Started doin it more and more and didn't quit after start up. I started taking it apart, oil was setting on top of the valves waiting to be dumped in the chamber. Also when I unplug the PCV oil come out of the plenum. I was reading up on it and i keep coming to valve seals or rings.. I could see valve seals leaking but to put that much oil on the valves seem unlikely. Something about if the rings was worn they could let compression pass the piston therefore pushing oil through the PCV into intake?
