basshead42
I hear of guys running e85 in their grand prixs. Are there and mods that need to be done to use this gas? What are the benefits? And does it have more octane than 94?
Larger injectors and a tune.
BH:
The E85 is quite a different animal, and is very corrosive to the entire fuel system. Vehicles that are OEM equipped to run on it are manufactured with parts that will withstand the volativity of the fuel.
Putting E85 into a vehicle not made for it will most likely result in a big repair bill for you later if not sooner.
I would research it completely so you know what you are getting into before you do this.
Don
BH:
Don
whoever told you e85 is corrosive was smoking crack.
read a chemistry book. ethanol (pure) is not corrosive. e85 (85% ethanol + 15% gas) is also not corrosive.
I have a 2007 grand prix GT along with the mods in my sig, do still need to change injectors to run E85?
Thanks
yes. yes you do. the stock injectors wont run enough fuel to keep up on e85. youll need to use about 30% more fuel.
the reason why ethanol is worse off than gas is if your car sits a lot youll have problems with water collecting in comparison to gas. that is what will eat away your fuel system not the fuel itself. if your car sits a lot i would not suggest running e85, but if you start it up every so often or drive it a few times a week at least then youre money. e85 will not eat away anything any more than regular gas would so i wouldnt be scared at all to run it.
ive done my fair share of research on it as well since i am planning on running it at some point.
im not sure which ones you need for your car. i would look at ZZP for what you need and then try to find them somewhere else cheaper.
