T
TDCRacing
Guest
I have been following what you have been doing in the threads that were posted about E85 and setting aside all the cotroversy i'd like to hear how it turns out for you. So let me know.
im sure youll all hear about it come spring time, but for now im just sitting on everything that i have because its my DD and no one wants to work in the cold on a car that is going to get you all wet.
and i cant use the power either in the snow or the cold pavement.
If you just want mid 11's how about a Gen V, 125 shot, race gas, and some tuning? If that doesn't get ya there than port the heads some and call it good. Oh and have you thought about trying to raise the compression?I want to be able to run 11.5's on a 75 shot. Maybe off of one? Just dont know how possible that is. I don't know of a lot of people that run faster than me on here that have an m90 setup. So it's hard to guess at what will work and what wont.I don't have a lot of experience on what part combo's people are using to go faster than 12's with a m90 setup is what i'm saying.
yeah, those heads should work out well on your setup. i dont know how exactly you reach the .600/.601 lift the IS4 has, but do you really want to go that big?
IMO if you run fully ported heads and you are going to stay m90 the XPZ is your best bet if you dont want to go full XPZ a S1X or XP will also make good power. Stage 3 and 4 cams tend to like a larger power adder to be worth it. However if you do plan on running nitrous you may be able to get away with a bit bigger cam. The problem you run into here is that a M90 loves a intake bias cam and a nitrous setup will love a exhaust bias cam. So you will have to make that choice.
