Horn location/repair
PLAYTME
I did a search but no luck so here I go, I have no horn when I hit it from the steering wheel. Where do they hide the horn in the engine bay and what does it they look like? I found 2 horns that look like something that belong on a tractor trailer, not conected to anything, is that stock?
1998 2 door GT
Thanks, Joe
^^^ Yup. Pull the passenger side headlight out and there it is. Check wires, grounds, recheck fuses.
It would really suck to have to take out the air bag and figure out how the switch works.
if you have two big rig horns under the hood, they are aftermarket ones someone put in. They may have wired them up.... causing the horn issues. Might be a simple fix, might not. Good luck!
Can you post a pic just to make sure what we're talking about?
I cant get in there to get a picture. They look like something a circus clown would honk with out the black ball on the end.
All wires are missing from what I can see. Havent taken out the p.s. headlight yet I am waiting on new headlights to arive to get into that.
Thanks for the help
You already know its been screwed with.
So hopefully all you will be doing is properly reattaching bad wires.
