:th_thumbsup-wink:
I was just getting on here to say I found a local shop that was going to punch out the pattern for me, but now that I see this, I'll get on it.
Must be a newer dodge. The pattern on the '01 era is too large of an opening.
Thanks for the link, think they look pretty nice in there, would also like to know how he attached them.
Can anyone get a measurement on the hole opening across the flats on the hexagon shape in a newer ('03+) dodge grille? I just measured an '01 and it is just under 3/4". The openings on our stock nose grilles are 1/2".
Does it need to be perfect? If it's that big of a concern, do the lower piece, and then use some more to replace the stock grills too.
I'd find the first one I could get, and then use the grills to make ones for the lower fascia and then cut more to replace the upper ones so they match. It'd be similar style but different, and they'd match eachother so...
I'd rather they stick out further, otherwise they're not noticeable enough imo. It'd look 10x better w/ an SD Air Dam too.
I wanna try this now.. looks sweet. You could alway cut some of the top of the grille so it sits farther forward and actually pops out of the lower fascia.
I like what newarkk is saying, too. What could be used for a "border" around the outer perimeter to make it look finished?
