Hippo Machine
Because Wet Leaves
Hows that look?
Impulse bought an amp that I kinda got a deal on. It's a 2 channel 80w rms x 2 @ 4 ohm amp, for my two front speakers!!!
It's a Boston Acoustics GTA-802 hope it fares well.
Your only amplifying the front now along with your subs? What about the rears? Also, installation just got a bit more involved with a two amplifier setup. Going to need a distribution block for your ground and power, 2 more sets of rcas for your right and left full range inputs, find a place to mount both of them, and then run new speaker wire from your two channel amplifier to your new front door speakers. Let us know if you need any more help with this larger burdon.
I've seen peeps use 0ga wire for the big 3 and they actually picked up a mpg.
Wouldn't doubt it. Modern day cars depend so much on the electrical running smoothly, if you have better, less resistant flow... anything is possible.
