Hippo Machine
Because Wet Leaves
Or is there a better solution to the flimsy terminal cup
Thanks. But what are your thoughts on putting the tweeters in the box too?
plus, putting an itty bitty tweet in a big ol' sub box without sealing off the area behind the tweet will make them sound jank as well.
Do your thing. Im telling you, you wont even hear them in the trunk. The 2000-20,000Hz frequencies arent going to penetrate your seats/rear deck. But I say find out for yourself, this will be a good learning experience for you.I want to do a experiment. I'm gonna make two tiny enclosures for the tweeters to keep the pressure of the sub away from them, then mount them in the subwoofer enclosure. Maybe I can do something where I can unplug them if they sound bad or if I just want them on with the trunk open. Good thing I took geometry!!
Ik most of you will disapprove but I want to try it out.
Oh and I'm home and checked out the tweeters..."f*cking huge.
Oh they sure will. Imagine...you have a 1" hole in your tire. You plug that hole with a 1" speaker. You think your tire will hold air? Kind of a dramatic example, but speakers are designed to let air through.The tweeters wouldn't cause any seal issues.. They are surrounded by like a big ceramic cone.plus I would seal with that caulk type stuff also
Started doing the calculations, 10x14x18 is too small, because I want to do a 1.5" thick face, so its only .92 cu. ft. without considering dispalcement. Thinking probably 10x14x20, but still have to do all of the calculations.
