Hippo Machine
Because Wet Leaves
Honestly....seal the doors with dynamat/sound deadener/second skin/raamat...whatever product you choose. Next, don't use the stock tweeter and see if you like it, then use the stock tweeter and see if you like it. I have a feeling it might sound better without it. Once you seal up those doors, put a layer of ensolite between the door skin and panel. When replacing the mid...make a pancake out of duct seal right behind it making sure to put as many non symetrical shapes as you can on the surface.
I have the tweeter unplugged currently and it sounds fine, just lowers the sound stage a bit. Do you know any 6 ohm tweeters that I should get?
As for the dynamat, I have 2 10" sheets, where is the best place to put them that is easyy?
