I'm back to this again. I have a 02 GTP. When starting the vehicle it will idle at 2,000 RPM's When warm it will idle at 3,200-3,500 RPMs.
The following have been replaced/tested
TPS, IAC, MAF, smoke test (with no leaks detected)
I can see the TPS adjust in the Torque as well as The IAC position adjust as the engine warms up and while accelerating. Although when at idle is it showing a position of 0. That is fully open I believe yes?
I'm just trying to figure out what else would be causing this high idle.
Any thoughts?
Thanks in advance.
Kurt.
Any thoughts?
Thanks in advance.
Kurt.
