hid question
t wizzle17
I bought the error eliminators for my high/lows and have never had a problem and I put hid in my fog lights and now it says my highbeamsbarebon and on my hud it flashes sometimes . Would I be better off also getting error eliminators for ny fogs ?? I'm running 8k DDM FOGS
My hids trip the high beam indicator all the time, I've just ignored it really. I think because the fogs are on the light slows up dim on the dash and light up in the HUD.
I just run VVME low beams with retro fits.
Check the wiring. Beam indicator comes on when wires are hooked up wrong. I have no eliminations, just a harness, and everything works as it should, even the HID fogs.
+1
Mine did the same thing. Never noticed I had the relay harness wired wrong until I got rid of the sh*** headlight housing's I had. Once I went back to some new factory housings I noticed I had the low and high beam pinned out wrong. Before I fixed it with just parking lights and fogs on the high beam indicator was dim in dash and flickered occasionally in the HUD. After I switched the pins on the headlight plug for the relay harness that issue disappeared.
