HID Help
TeeMurr
I'm looking to put DDM 35W 8K HIDs in my wife's 2005 Grand Prix SE. I'm going to do the lows, highs, and fogs. I have a couple of questions.
1) I want bright lights because hers are dim, but I would like a light blue tint to them, I don't want to put in 55W because of the high temp, would anyone recommend a different color like 6K?
2) Do I need anything else other than the kit? Like the error eliminator?
3) Also, how hard was the installation?
Thank you in advance for your help.
HIDs in the high beams on 04+ is useless because the bulbs wouldn't be warm enough to be useful if you wanted to flash them as example. It's pretty easy install just plug and play. The color depends on what you want, better useable light or the color. Are you housings all foggy and cracked?
Sent from my HTC Thunderbolt using Tapatalk
1) 6k would be your best bet for a slight blue. Normally I stick with either 4300 or 5k but since you want that blue tint, 6k is your best bet.
2) Better run a relay harness to avoid messing up your electrical system.
3) simple pnp
Running a hid kit for the high is unnecessary. They need time to warm up and by the time you use the highs it'll be pretty useless just stick to a halogen in there not to mention the added stress of running 3 hid systems.
I won't go into to much detail on how bad hids are in reflector based headlights but please for the love of god make sure you aim the headlights correctly so your not glaring oncoming traffic to bad.
Thank you for the help. My route to work is through some unlit back country roads and I occasionally take her car with me. When I go in there's no light which is the reason I was planing on doing the highs. Or with the lows and the fogs being HID will I not even want them anymore?
The housings are a little foggy, I've cleaned them before and this time I'm going to do the full restoration kit, but I'm set on putting in HID's anyways.
And I will deffinitely make sure they are aimed correctly, I would hate to glare someone else.
I never used my highs again after I went the hid route years ago if that tells you anything. Try just the lows and fogs first then decide if the highs are still needed.
I don't know much about halogen bulbs but you should be able to find some decent ones for you highs.
Low beam hids are bright enough If your wanting light on the road I wouldnt go any higher than 5k...
Just an FYI I have 6k and are much brighter than stock...I also adjusted headlight angle so they don't blind on coming drivers
4300-5000 give the whitest most usable light, after that they get more blue. Most HIDs will shift color over time (especially cheap ones) so go lower kalvin. From 4300 to 6000k you lose about 300 lumens. And you may have them aimed straight to the ground, but I guarantee your pnp HIDs are obnoxious to other drivers
Funny cause I've been driving another vehicle headed home and my mom took my car and I passed her....and I swear the lights didnt blind or annoy me
You are subjective to it because its your car. This thread is full of your people http://www.hidplanet.com/forums/showthread.php?37924-the-hid-fail-gallery
I'm not subjective to it because its my car. I have seen others that weren't bothering because they were done right. Sorry that what I think isn't fun*king good enough but its my opinion. You may know a lot or u may think u do..and I'm not saying everything I say is right...but I know I've seen other HIDs that aren't blinding or annoying
Fu*king noobs think they know everything.
Well I just found the smartest man on the internet.
But OP, sorry for derailing your topic. I'm not saying that HIDs are a bad idea but they scatter bright light everywhere and if it happens to be raining or foggy you won't have really any better light on the road. The only lights that should have them is lows, because the highs would fail sooner from being turned on and off more often, and fogs don't go out very far so it is just added foreground light and that isn't where you want light. So with just getting lows you could get your HIDs from theretrofitsource.com and it will be a quality lasting product. Error eliminator won't be needed. 55w will fail sooner than 35w, so another reason to do 35w. The install will be pretty easy, just finding points to ground the relay harness to is the only thing that takes real thought
They are a bad idea. Get some good 9006s for the lows, or HIRs. Don't blind people. Your car will look like a ricer. Even if you aim them down to not blind people, you'll blind yourself with the foreground if you go anywhere that is truly dark, IE no city lights.
Don't buy into the HID bandwagon.
Or retrofit projectors. If you have hazy/dark headlights then get new assemblies and bulbs, because bulbs will dim over their life
HID's in a halogen capsule have glare. No ifs ands or butts.
It may seem different to some, but that depends on heights and angles.
I've had HID's in stock housing for almost 10 years now; I get the odd flash. I just flash them back. They should be thankful that I am in a lowered car rather than a lifted truck.
Haha, knock on wood, my friend got stopped for having too green of bulbs in the fogs but his were pretty darn yellow. And the 97-03s have awful stock lights so that's why they don't notice
