HID Help
try wiring it up without the relay harness, first then hooking up the harness
and yes the black wires go to ground
they work with the stock wiring but not with the harness. maybe im not getting a good connection from the battery?
yea...
heres were my grounds are
the ground on the harness, on one side and the ground on the bulb on the other side, then the power(red) on the top post on the fuse block
the one that you told me to plug in has two little wires coming off of it.. what should i do with those a red and a black. idk what it was doing but the car wasnt getting any power
i have no clue what those are for as long as your giving the relay a power and ground then it shouldnt matter,,,the car isnt getting power?..what?..like the batterys dead
well that doesnt make any since...youu couldnt start your car with it plugged in?..what about it unplugged?....
that blue piece should go to the factory plug..something on that harness has to plug into the factory wiring.
is fine on your stock wiring..are they 55w?...i wouldnt keep it like that but its fine for a little while
