Hesitation and long starts, Please help!
[TABLE="class: content"]
[TR]
[TD="class: body1"]
Reference: Fuel System Pressure Test
[TABLE="class: MsoNormalTable, width: 100%"]
[TR]
[TD="width: 50%"]
Document ID# 564570
2000 Pontiac Grand Prix
[/TD]
[TD="width: 25%"][/TD]
[/TR]
[/TABLE]
[TABLE="class: MsoNormalTable"]
[TR]
[TD][/TD]
[/TR]
[TR]
[TD]
(1)​
[/TD]
[TD]Fuel Pipe Shut-off Adapters
[/TD]
[/TR]
[TR]
[TD]
(2)​
[/TD]
[TD]Fuel Return Pipe
[/TD]
[/TR]
[TR]
[TD]
(3)​
[/TD]
[TD]Fuel Pump Flex Pipe
[/TD]
[/TR]
[TR]
[TD]
(4)​
[/TD]
[TD]Modular Fuel Sender
[/TD]
[/TR]
[TR]
[TD]
(5)​
[/TD]
[TD]Fuel Feed Pipe
[/TD]
[/TR]
[TR]
[TD]
(6)​
[/TD]
[TD]In-Line Fuel Filter
[/TD]
[/TR]
[TR]
[TD]
(7)​
[/TD]
[TD]Fuel Rail Assembly
[/TD]
[/TR]
[TR]
[TD]
(8)​
[/TD]
[TD]Fuel Pressure Regulator
[/TD]
[/TR]
[TR]
[TD]
(9)​
[/TD]
[TD]Fuel Pressure Guage
[/TD]
[/TR]
[/TABLE]
Circuit Description
When the ignition switch is turned ON, the Powertrain Control Module (PCM) will turn ON the in-tank fuel pump. The in-tank fuel pump will remain ON as long as the engine is cranking or running and the PCM is receiving reference pulses. If there are no reference pulses, the PCM will turn the in-tank fuel pump OFF 2 seconds after the ignition switch is turned ON, or 2 seconds after the engine stops running. The in-tank fuel pump is an electric pump within an integral reservoir. The in-tank fuel pump supplies fuel through the fuel feed pipe, and in-line fuel filter to the Fuel Rail Assembly. The fuel pump is designed to provide fuel at a pressure that is above the pressure needed by the fuel injectors. A fuel pressure regulator, attached to the Fuel Rail, keeps the fuel available to the fuel injectors at a regulated pressure. Unused fuel is returned to the fuel tank by a separate fuel return pipe. The fuel pressure gauge J 34730-1A and fuel pipe shut off adapters J 37287 are used for fuel system diagnosis.
Test Description
The numbers below refer to the step numbers on the Diagnostic Table.
2.This step tests the system's ability to achieve the specified fuel pressure.
3.A fuel system that drops more than 5 psi during 10 minutes has a leak in one or more of the following areas:
[TR]
[TD]-
[/TD]
[TD]The fuel pump check valve
[/TD]
[/TR]
[/TABLE]
[TR]
[TD]-
[/TD]
[TD]The fuel pump flex pipe
[/TD]
[/TR]
[/TABLE]
[TR]
[TD]-
[/TD]
[TD]The valve or valve seat within the fuel pressure regulator
[/TD]
[/TR]
[/TABLE]
[TR]
[TD]-
[/TD]
[TD]The fuel injectors
[/TD]
[/TR]
[/TABLE]
5.Fuel pressure that drops-off during acceleration, during cruise, or during hard cornering may cause a lean condition. A lean condition can cause a loss of power, surging, or misfire. You can diagnose a lean condition with scan tool. If an extremely lean condition occurs, the oxygen sensors will stop toggling. The oxygen sensor output voltages will drop to less than 500 mV. Also, the fuel injector width will increase.
Important: Ensure that the fuel system is not operating in the Fuel Cut-Off Mode. This can cause false indications from the scan tool.
8.When the engine is at idle, the manifold pressure is low, indicating a high vacuum. This low pressure is applied to the fuel pressure regulator diaphragm. The low pressure will offset the pressure that is being applied to the fuel pressure regulator diaphragm by the spring inside the fuel pressure regulator. When this occurs, the result is lower fuel pressure. The fuel pressure at idle will vary slightly during barometric pressure changes, but the fuel pressure at idle should always be less than the fuel pressure noted in Step 2, with the Engine OFF.
12.A rich condition may result from the fuel pressure being above 376 kPa (55 psi). A rich condition may cause a DTC P0132 or a DTC P0172 to set. Driveability conditions associated with rich conditions can include hard starting followed by black smoke, and a strong sulfur smell in the exhaust.
13.This test determines if the high fuel pressure is due to a restricted fuel return pipe, or if the high fuel pressure is due to a faulty fuel pressure regulator.
15.A lean condition may result from fuel pressure that is less than 333 kPa (48 psi). A lean condition may cause a DTC P0131 or a DTC P0171 to set. Driveability conditions that are associated with lean conditions can include hard starting when the engine is cold, hesitation, poor driveability, lack of power, surging, and misfiring.
16.Restricting the fuel return pipe with the fuel pipe shut-off adapter causes the fuel pressure to rise above the regulated fuel pressure. Use a scan tool in order to pressurize the system. The fuel pressure should rise to more than 376 kPa (55 psi) when the valve on the fuel pipe shut-off adapter that is connected to the fuel return pipe becomes partially closed.
Notice: Do not allow the fuel pressure to exceed 450 kPa (65 psi). Fuel pressure in excess of 450 kPa (65 psi) may damage the Fuel Pressure Regulator.
22.Check the spark plug that is associated with a particular fuel injector for fouling or for saturation in order to determine if that particular fuel injector is leaking.
[TR]
[TD]
Step
[/TD]
[TD]
Action
[/TD]
[TD]
Value(s)
[/TD]
[TD]
Yes
[/TD]
[TD]
No
[/TD]
[/TR]
[TR]
[TD]
1​
[/TD]
[TD]Did you perform the Powertrain On-Board Diagnostic (OBD) System Check?
[/TD]
[TD]
[/TD]
[TD]
Go to Step 2​
[/TD]
[TD]
Go to Powertrain On Board Diagnostic (OBD) System Check​
[/TD]
[/TR]
[TR]
[TD]
2​
[/TD]
[TD]
  1. Turn OFF the ignition.
  2. Turn OFF the air conditioning system.
Caution: Wrap a shop towel around the fuel pressure connection in order to reduce the risk of fire and personal injury. The towel will absorb any fuel leakage that occurs during the connection of the fuel pressure gage. Place the towel in an approved container when the connection of the fuel pressure gage is complete.
  1. Install the J 34730-1A fuel pressure gauge.
  2. Place the bleed hose of the fuel pressure gauge into an approved gasoline container.
  3. Turn ON the ignition.
  4. Bleed the air out of the fuel pressure gauge into an approved gasoline container.
  5. Turn OFF the ignition for 10 seconds.
  6. Turn ON the ignition.
Important:: The fuel pump will run for approximately 2 seconds. Cycle the ignition as necessary in order to achieve the highest possible fuel level
  1. With the fuel pump running, observe the fuel pressure that is indicated by the fuel pressure gauge.
Is the fuel pressure within the specified limits?[/TD]
[TD]
333-376 kPa (48-55 psi)​
[/TD]
[TD]
Go to Step 3​
[/TD]
[TD]
Go to Step 12​
[/TD]
[/TR]
[TR]
[TD]
3​
[/TD]
[TD]Important: The fuel pressure may vary slightly when the fuel pump stops running. The fuel pressure should stabilize and remain constant. Note the fuel pressure after the fuel pump stops running.
Does the fuel pressure drop more than the specified value in 10 minutes?
[/TD]
[TD]
34 kPa (5 psi)​
[/TD]
[TD]
Go to Step 10​
[/TD]
[TD]
Go to Step 4​
[/TD]
[/TR]
[TR]
[TD]
4​
[/TD]
[TD]Relieve the fuel pressure to the specified value. Does the fuel pressure drop more than the specified value in 10 minutes?
[/TD]
[TD]
69 kPa (10 psi)
14 kPa (2 psi)​
[/TD]
[TD]
Go to Step 19​
[/TD]
[TD]
Go to Step 5​
[/TD]
[/TR]
[TR]
[TD]
5​
[/TD]
[TD]Is the fuel pressure suspected of dropping-off during acceleration, during cruise, or during hard cornering?
[/TD]
[TD]
[/TD]
[TD]
Go to Step 6​
[/TD]
[TD]
Go to Step 8​
[/TD]
[/TR]
[TR]
[TD]
6​
[/TD]
[TD]Inspect the following items for a restriction:
[TR]
[TD]•
[/TD]
[TD]The in-line fuel filter
[/TD]
[/TR]
[/TABLE]
[TR]
[TD]•
[/TD]
[TD]The fuel feed pipe
[/TD]
[/TR]
[/TABLE]
Did you find a restriction?[/TD]
[TD]
[/TD]
[TD]
Go to Step 24​
[/TD]
[TD]
Go to Step 7​
[/TD]
[/TR]
[TR]
[TD]
7​
[/TD]
[TD]
  1. Remove the modular sender assembly. Refer to Fuel Sender Assembly Replacement .
  2. Inspect the following components:
[TR]
[TD]-
[/TD]
[TD]The fuel pump strainer for a restriction
[/TD]
[/TR]
[/TABLE]
[TR]
[TD]-
[/TD]
[TD]The fuel pump strainer for correct position, and for correct installation on the fuel sender assembly
[/TD]
[/TR]
[/TABLE]
[TR]
[TD]-
[/TD]
[TD]The fuel pump flex pipe for leaks
[/TD]
[/TR]
[/TABLE]
[TR]
[TD]-
[/TD]
[TD]Verify that the fuel pump is the correct fuel pump for this vehicle
[/TD]
[/TR]
[/TABLE]
Did you find a problem in any of these areas?[/TD]
[TD]
[/TD]
[TD]
Go to Step 24​
[/TD]
[TD]
Go to Step 19​
[/TD]
[/TR]
[TR]
[TD]
8​
[/TD]
[TD]
  1. Turn OFF the ignition for 10 seconds.
  2. Turn the ignition ON.
Important:: The fuel pump will run for approximately 2 seconds. Cycle the ignition as necessary in order to achieve the highest possible fuel level. Note this pressure.
  1. Start the engine.
  2. Allow the engine to idle at the normal operating temperature.
Is the fuel pressure less than the noted fuel pressure by the amount specified?[/TD]
[TD]
21-69 kPa (3-10 psi)​
[/TD]
[TD]
Go to Symptoms​
[/TD]
[TD]
Go to Step 9​
[/TD]
[/TR]
[TR]
[TD]
9​
[/TD]
[TD]
  1. Disconnect the vacuum hose from the fuel pressure regulator.
  2. With the engine idling, apply 12-14 inches of vacuum to the fuel pressure regulator.
Does the fuel pressure drop by the amount specified?[/TD]
[TD]
[/TD]
[TD]
Go to Step 20​
[/TD]
[TD]
Go to Step 21​
[/TD]
[/TR]
[TR]
[TD]
10​
[/TD]
[TD]
  1. Relieve the fuel pressure. Refer to Fuel Pressure Relief Procedure
  2. Disconnect the fuel feed pipe and the fuel return pipe from the fuel rail. Refer to Quick Connect Fitting(s) Service (Metal Collar)
  3. Install the J 37287 fuel pipe shut-off adapters between the fuel feed pipe and the fuel return pipe and the fuel rail.
  1. Open the valves on the fuel pipe shut-off adapters.
  2. Turn OFF the ignition.
  3. Use a scan tool in order to pressurize the fuel system.
  4. Place the bleed hose of the fuel pressure gauge into an approved gasoline container.
  5. Bleed the air out of the fuel pressure gauge.
  6. Wait for the fuel pressure to build.
  7. Close the valve in the fuel pipe shut-off adapter that is connected to the fuel feed pipe.
Does the fuel pressure remain constant?[/TD]
[TD]
[/TD]
[TD]
Go to Step 19​
[/TD]
[TD]
Go to Step 11​
[/TD]
[/TR]
[TR]
[TD]
11​
[/TD]
[TD]
  1. Open the valve in the fuel pipe shut-off adapter that is connected to the fuel feed pipe.
  2. Use a scan tool in order to pressurize the fuel system.
  3. Wait for the fuel pressure to build.
  4. Close the valve in the fuel pipe shut-off adapter that is connected to the fuel return pipe.
[TD]
[/TD]
[TD]
Go to Step 21​
[/TD]
[TD]
Go to Step 22​
[/TD]
[/TR]
[TR]
[TD]
12​
[/TD]
[TD]Is the fuel pressure above the specified limit?
[/TD]
[TD]
376 kPa (55 psi)​
[/TD]
[TD]
Go to Step 13​
[/TD]
[TD]
Go to Step 15​
[/TD]
[/TR]
[TR]
[TD]
13​
[/TD]
[TD]
  2. Disconnect the fuel return pipe from the fuel rail. Refer to Quick Connect Fitting(s) Service (Metal Collar)
  3. Attach a length of flexible fuel hose to the fuel rail return outlet passage
  4. Place the open end of the flexible hose into an approved gasoline container.
  7. With the fuel pump running, observe the fuel pressure gauge.
[TD]
[/TD]
[TD]
Go to Step 23​
[/TD]
[TD]
Go to Step 14​
[/TD]
[/TR]
[TR]
[TD]
14​
[/TD]
[TD]Inspect the fuel rail outlet passages for a restriction. Did you find a restriction?
[/TD]
[TD]
[/TD]
[TD]
Go to Step 24​
[/TD]
[TD]
Go to Step 21​
[/TD]
[/TR]
[TR]
[TD]
15​
[/TD]
[TD]Is the fuel pressure more than the specified value?
[/TD]
[TD]
0 kPa (0 psi)​
[/TD]
[TD]
Go to Step 16​
[/TD]
[TD]
Go to Step 17​
[/TD]
[/TR]
[TR]
[TD]
16​
[/TD]
[TD]
  3. Install the J 37287 fuel pipe shut-off adapter between the fuel return pipe and the fuel rail.
  4. Open the valve on the fuel pipe shut-off adapter.
  5. Turn OFF the ignition.
  6. Use a scan tool in order to pressurize the fuel system.
  1. Place the bleed hose of the fuel pressure gauge into an approved gasoline container.
  2. Bleed the air from the fuel pressure gauge.
  3. Slowly close the valve in the fuel pipe shut-off adapter that is connected to the fuel return pipe.
Does the fuel pressure rise above the specified value?[/TD]
[TD]
[/TD]
[TD]
Go to Step 21​
[/TD]
[TD]
Go to Step 7​
[/TD]
[/TR]
[TR]
[TD]
17​
[/TD]
[TD]Perform the Fuel System Electrical Test. Refer to Fuel Pump Electrical Circuit Diagnosis . Did you find a problem with the fuel pump electrical circuit?
[/TD]
[TD]
[/TD]
[TD]
Go to Step 24​
[/TD]
[TD]
Go to Step 18​
[/TD]
[/TR]
[TR]
[TD]
18​
[/TD]
[TD]Inspect the following components:
[TR]
[TD]•
[/TD]
[TD]The in-line fuel filter for obstructions
[/TD]
[/TR]
[/TABLE]
[TR]
[TD]•
[/TD]
[TD]The fuel feed pipe for a restriction
[/TD]
[/TR]
[/TABLE]
[TR]
[TD]•
[/TD]
[TD]The fuel pump strainer for obstructions
[/TD]
[/TR]
[/TABLE]
[TR]
[TD]•
[/TD]
[/TD]
[/TR]
[/TABLE]
Important: You must remove the fuel sender assembly in order to inspect the fuel pump strainer and the fuel pump flex pipe. Refer to Fuel Sender Assembly Replacement
[TD]
[/TD]
[TD]
Go to Step 24​
[/TD]
[TD]
Go to Step 19​
[/TD]
[/TR]
[TR]
[TD]
19​
[/TD]
[TD]Replace the modular fuel sender assembly. Is the action complete?
[/TD]
[TD]
[/TD]
[TD]
Go to Step 25​
[/TD]
[TD]
[/TD]
[/TR]
[TR]
[TD]
20​
[/TD]
[TD]Locate and repair the loss of vacuum to the fuel pressure regulator. Is the action complete?
[/TD]
[TD]
[/TD]
[TD]
Go to Step 25​
[/TD]
[TD]
[/TD]
[/TR]
[TR]
[TD]
21​
[/TD]
[TD]Replace the fuel pressure regulator. Is the action complete?
[/TD]
[TD]
[/TD]
[TD]
Go to Step 25​
[/TD]
[TD]
[/TD]
[/TR]
[TR]
[TD]
22​
[/TD]
[TD]Locate and replace any leaking fuel injectors. Is the action complete?
[/TD]
[TD]
[/TD]
[TD]
Go to Step 25​
[/TD]
[TD]
[/TD]
[/TR]
[TR]
[TD]
23​
[/TD]
[TD]Locate and correct the restriction in the fuel return pipe. Is the action complete?
[/TD]
[TD]
[/TD]
[TD]
Go to Step 25​
[/TD]
[TD]
[/TD]
[/TR]
[TR]
[TD]
24​
[/TD]
[TD]Repair the problem as necessary. Is the action complete?
[/TD]
[TD]
[/TD]
[TD]
Go to Step 25​
[/TD]
[TD]
[/TD]
[/TR]
[TR]
[TD]
25​
[/TD]
[TD]
  2. Turn OFF the air-conditioning system.
  4. Bleed the air from the fuel pressure gauge into an approved gasoline container.
  1. With the fuel pump running, observe the fuel pressure that is indicated by the fuel pressure gauge. Is the fuel pressure within the specified limits?
[/TD]
[TD]
[/TD]
[TD]
Go to Step 26​
[/TD]
[TD]
Go to Step 11​
[/TD]
[/TR]
[TR]
[TD]
26​
[/TD]
Does the fuel pressure drop more than the specified value during 10 minutes?
[/TD]
[TD]
34 kPa (5 psi)​
[/TD]
[TD]
Go to Step 10​
[/TD]
[TD]
System OK​
[/TD]
[/TR]
[/TABLE]
[/TD]
[TD="class: c_r"][/TD]
[/TR]
[/TABLE]
So did you get any resolution to your problem? I am having the same issue actually. This is a 2006 GP NA. The sputter isn't that bad, just more of a delay when accelerating. However, I am also having the starter issue as well.
