helpme spend 4 grand
Bio i would assume it would be 4 grand right....his title says "help me spend 4 grand"
Also what Bio said...what are you goals for the car?
turbo is bolt on.
You dont have to crack a single gasket on the motor.
even though you should.
the LIM and VC gaskets are probably leaking/going to leak in the next couple years.
And to answer: Searching Forums Query: maf upgrade
No, unless you're outflowing your stock one, theres no point. You're not going to gain anything.
and?
when you're done you put a plug in it.
I'm thinking take two GXP's and weld the second engine in the rear of the first car.
600 HP and two V8's.........
x2 thats where I'd put 4k
Like I posted earlier hes got a 04 already so it should have a Gen5 Id do cam headers E85 tune and Transmission. :th_biggrin2:
the cam kinda dictates what heads you'll wanna get.
with that setup, you'll be going fast. unless it's just an xp or vs or s1x cam. but if you're getting heads, get a bigger cam. high flow cat maybe? like bio said, what are your goals? 4k will get you a lot and you'll still have money for a TEP trans
