T
TDCRacing
Guest
Ok so after putting my car back together i am having a smoking issue. like it's buring oil or something. mostly notice it at idle. I think it has something to do with the intake and the intercooler...you are suppose to be able to run a breather in the front valve cover OR modify the lower intake so the pcv system works properly with the intercooler....i found this when i took my motor apart during the cam and tranny swap........it was not smoking before the swap...yes new valve seals and springs were installed!....
I think the motor was able to breath properly because this was not sealing properly....all i used was the gasket and obviously it didnt work or seal correctly. so when i put everything back together i used a lot of grey rtv (mainly because i had a vacume leak with just the gasket)...i think it has something to do with that...maybe...what do yall think? maybe burning oil because the crank case cant breath or something...going to pull all the plugs tomorrow.
