Help with factory nav
Posty101
I recently installed a factory nav unit out of a 2007 gp into my 04 comp g.
Everything works besides the navigation getting gps signal. It just looks like this
Did all the plugs line up in the back?
Wanted to do this for while but hesitated because did t wanna buy the gxp radio if it didnt work.
Sent from my SM-G928V using Tapatalk
you have to run a wire form the back of the headunit to the the green Vehicle Speed Sensor wire connected to the PCM under the hood.
http://www.grandprixforums.net/threads/63877-How-to-add-factory-nav-to-an-05-08-with-HUD
seems there has been a lot of question on this specifically (pin location on either end) next time I open my dash I will get apic and also os the VSS on the PCM. without the VSS wire your GPS will never actually function properly with identifying its own location and also putting directions on your HUD which is the other benefit of the factory nav unit.
