the metal gasket (the one closest to the firewall) bolt holes on the passenger side weren't aligned on that side of the gasket, but the bolt holes were aligned on the same metal gasket (the one closest to the firewall) on the other side.
I pulled the LI manifold up a little on the passenger corner and stuck the end of a very small screwdriver into the bolt hole and gently pulled on the metal gasket a tad. after this, all the holes appeared aligned and I was able to bolt the LI down.
I just find it weird. I didn't check the bolt holes when I put the gaskets on (my fault) and only noticed those few holes where the gasket was in the way of the holes. and since the gasket has the tabs, I didn't think it could move or flex.
how many times are you going to say the same thing? its fine im sure.
