Help please reduced engine power p2135 and p0122
jteske88
So got this today and need my car, I can pull battery and code will disapeer but comes back about a block or two from the house. And what I can tell it does it at a certain point In the throttle position so please help anyone
A P0122 code means that the the car's computer has detected that the TPS (throttle position sensor) is reporting too low a voltage. On some vehicles that lower limit is 0.17 - 0.20 volts (V).
DTC P0122
CIRCUIT DESCRIPTION
The throttle body assembly contains 2 throttle position (TP) sensors. The TP sensors are mounted to the throttle body assembly and are not serviceable. The TP sensors provide a signal voltage that changes relative to throttle blade angle. The engine control module (ECM) supplies each TP sensor with a 5-volt reference circuit, a low reference circuit, and a signal circuit.
The TP sensors have opposite functionality. TP sensor 1 signal voltage decreases from above 4 volts at idle to below 1 volt at wide open throttle (WOT). TP sensor 2 signal voltage increases from below 1 volt at idle to above 4 volts at WOT.
If the ECM detects TP sensor 1 signal voltage is too low, this DTC sets.
DTC P2135
CIRCUIT DESCRIPTION
The throttle position (TP) sensors 1 and 2 are located within the throttle body assembly. The TP sensors share a common 5-volt reference circuit and a common low reference circuit. The 5-volt reference circuit is also shared with the accelerator pedal position (APP) sensor 2. The 5-volt reference voltage is supplied on 2 separate engine control module (ECM) terminals, but the terminals are connected internally to the same voltage supply. Each TP sensor has an individual signal circuit, which provides the ECM with a signal voltage proportional to throttle the plate movement. When the throttle plate is in the closed position, the TP sensor 1 signal voltage is near the low reference and increases as the throttle plate is opened. The TP sensor 2 signal voltage at closed throttle is near the 5-volt reference and decreases as the throttle plate is opened. If the ECM detects that the TP sensors are not within a predicted value from each other, DTC P2135 sets.
DTC DESCRIPTOR
This diagnostic procedure supports the following DTC:
DTC P2135 Throttle Position (TP) Sensor 1-2 Correlation
CONDITIONS FOR RUNNING THE DTC
  • DTCs P0122, P0123, P0222, P0223, P0601, P0602, P0603, P0604, P0606, P0607, P0641, P0651 are not set.
  • The ignition is ON.
  • DTC P2135 runs continuously when the above condition is met.
CONDITIONS FOR SETTING THE DTC
The ECM detects that the difference between TP sensor 1 and TP sensor 2 is more than the predicted value for less than 1 second .
ACTION TAKEN WHEN THE DTC SETS
  • The control module illuminates the malfunction indicator lamp (MIL) when the diagnostic runs and fails.
  • The control module records the operating conditions at the time the diagnostic fails. The control module stores this information in the Freeze Frame and/or the Failure Records.
  • The control module commands the TAC system to operate in the Reduced Engine Power mode.
  • A message center or an indicator displays Reduced Engine Power.
  • Under certain conditions the control module commands the engine OFF.
CONDITIONS FOR CLEARING THE MIL/DTC
  • The control module turns OFF the malfunction indicator lamp (MIL) after 3 consecutive ignition cycles that the diagnostic runs and does not fail.
  • A current DTC, Last Test Failed, clears when the diagnostic runs and passes.
  • A history DTC clears after 40 consecutive warm-up cycles, if no failures are reported by this or any other emission related diagnostic.
  • Clear the MIL and the DTC with a scan tool.
