riceburner
the leak is on the #3 actually...but ya i am going to tow it home tommorrow and i guess tear into it and replace those gaskets...could the coolant be leaking in and causing a bad fire?
Dont mean to be a dick about anything but I told you to do a compression test MANY times over 20 days ago here and at clubgp. Sorry that happened. Stock head gaskets are some of the best, good luck. Next time instead of wasting money on sensors and what not begin with basic troubleshooting things such as checking fuel and spark. If you have that then do a compression test. Hopefully you and others learn from this experience.Do a compression test, I think I told you that over at clubgp. You have fuel and spark, so you should atleast be able to turn it over and it fire. If the engine doesnt have compression it will run like crap or not run at all. Also, get someone to pull the codes. If your coolant seems low you may have blown a headgasket.
