HELP need opinions
i have fixed all possible vacuum leaks and my ltft is still pegged at 16.4 at idle. MAP reads 11.25 inhg. maf is healthy only other thing i could think of is a MAP is bad opinions?
Have you checked fuel pressure? It could be low and attempting to fuel it more due to lack of fuel pressure.. Also could have low fuel volume
fuel pressure is good round 55 psi i have a map sensor of a 3.4 l im gunna try tommorow. just gotta get the connector to go in. and im gunna get that vacuum gauge and test that
well map sensor is good. i deleted the egr today and now rpms bounce like crazy at idle, but my map reading is where it should be. i unplugged the MAF sensor and it smooths out at idle and will sit at 1500 rpm. is it time for a new MAF sensor?
