Hardonyomom
So i looking for help from anyone that has installed this big ass heat exhanger. So far i got A piece of angle iron steel that i going to drill through to attach the heat exchanger to the bottom of the beam of the bumper, NOT the radiator support. The bracket will either wit flush with the beam or it will in more to give an extra inch or so. Here is some pictures of what i got going on if anyone has done this install with a heat exchanger other than zzp, please feel free to help out. thanks
I took this fitting off since its used to drain liquid and i put a plug on that i can take off at anytime as well.
How would you go about this project?
