Help me please
macey43
Hey guys, my car has really been pissing me off lately. So what it's doing is I can step on the gas and I basically just won't accelerate. The car will sound kind of boggy and I can get to about 40 mph without really pushing it where the problem will probably get worse. When I turn the car off I can hear air being expelled from the air intake as if it can't escape through the exhaust.
The car also threw a po410 code- secondary air injection fault... Emissions or what? Either way, I'm leaning towards a plugged cat what do you think?
Very well could be a clogged cat, if so, you need to find out what caused the cat. to melt down (overheat). Or a replacemant will get damaged too.
I agree, sounds like a bad cat. If your car has over about a 120k it wouldn’t hurt to replace it, they don’t last forever. And definitely scan it afterward, to see if that was the cause of your problems. Or just the symptom. :th_winking:
So basically **** rusty bolts haha. Anyway my car has 71 k on it... But the only other thing I can think of would be the maf. Does anyone know how to tell if one of these is bad using a multimeter?
I’m not aware that you can with a multi-meter. Most people disconnect it, then see if the car runs better.
