des19
Re: boost gauge intall?
which fuse is the heater circuit fuse? underhood fusebox or in car?
Now diagnose it.. Look up the code and check the heater circuit fuse.
As for the vacuum line. It doesn't matter where you T into the line. You need to be hooked in anywhere on the horseshoe of line from BCS to FPR to LIM to MAP. Doesn't matter a bit where in that line you tap in. Not sure why Blueguy was pushing you to put it in a nice clean location vs making a mess under the snout.
