HELP! Is my rocker screwed?
Infinity9999
Trying to diagnose a major ticking issue on my rockers and found this:
Am I screwed?
Means it bounced off...check the pedestal...sure you didn't put it on backwards? It is easy to confuse. You can probably buy a new one from Pro Magnum but I wouldn't reuse it IMO.
The ProMags don't use pedestals. They just bolt right on. I have a feeling it was installation error from the shop that moved them over from my 97 when I bought the 04 from them. I'm checking with ZZP (where I bought them) as well as CompCams to find out what my options are. I think I'll probably get 3 good pairs on the back so that I don't have to go through the hassle of getting back there again. I should probably check my rod too.
Might be a good idea...I had the same issue with Yella Terra 1.84's on one rocker too...I sold them to a local for $125 when I did my cam swap and he just bought 1 new rocker as everything else was fine. Hope you get it figured out man.
