Hi guys,
I have a 97 GTP and just installed aftermarket headers, crossover, midpipe, held together by band clamps and u clamps, I also replaced the rear o2 sensor. After the header install, I can't rev past 4k RPM in park or neutral and supercharger sound is gone. Also, the car bogs down going up hill 45mph and I feel like I have lost power on acceleration.
Weird thing is, I wasn't getting any reading from the MAF sensor and got the P0102 code right after header install. I fixed this by replacing the 21 fuse. The only reason I can think of it blowing this fuse is the precat o2 sensor wire was touching the rear header, I can not think of any other reason.
Right now, I am getting reading from front and rear o2 sensors AND the MAF and everything looks correct.
I do know there is an exhaust leak from the mid pipe near the rear o2 sensor. Only one bolt in the flange as the other bolt was seized and snapped off when taking it out. I doubt this is what could be causing it, but just wanted to throw that out there. No other exhaust leak that I know of.
I personally think it could be a vacuum leak or maybe I put a vacuum line in the wrong place? I took apart a lot of the vacuum lines, does any one have a good diagram to see where each vacuum line goes? Or does any one have any idea what could be causing this problem? No check engine lights yet, although I am expecting the p0420 code to pop up anytime now
