Colossus
So I had been driving with my ABS/Traction Off light on for a couple months....finally changed the Hub Assembly last week (front passenger). I bought a Timken hub Assembly from Auto Zone and installed it according to the thread
http://www.grandprixforums.net/f73/how-to-replace-front-hubs-10985.html
And torqued the bolts according to mystic231 on that same thread
-Hub bolts: 96 foot lbs
-Brake Calliper bolts: 133 foot lbs
-36 mm axel bolt: 159 foot lbs
-tire bolts: 100 foot lbs
Light went off and 2 days later it started sqealing, quiet at first, now louder. I took the tire off today and checked things out. I loosened the 36mm, and re-torqued it to 110lbs (saw that number on another site).
Took it for a drive and it still squeaks (loud!), the ABS/Traction Light is still OFF, and it only squeaks when driving straight and/or there is pressure on that side/tire (right). Sound dissapears when I turn to the Right, putting pressure on the left side of the car, and releaving it from the right side/tire.
Also, i never had this sound while driving on the bad assembly,, just the common "propeller" sound.
Anyone have some helpful advice!??
Thanks.
Thanks.
