Help!! 97 grand prix problems
schmidtt
I have a 97 grand prix gt. the radio, the heated seats and the keyless entry are not working. The fan speed only works on high (5). The radio has no display but the volume and equalizer and all that light up when i turn the lights on it and does not have audio so i bought a new cd player and that did not work either so i dk whats wrong. i checked all the fuses and there all good. i bought a new battery for keyless remote and it still does not work. i noticed the radio, remote entry, hvac are on same fuse under the hood but the fuse is good. DO you have any ideas? Thanks!
Sounds like you have a multitude of problems. The fan speed only working on high sounds like you need a new blower motor. The radio display is a bulb that has a tendency to blow. Heated seats are another area where things just quit working. As for your RKE, you may need to re-sync your fob(s) to the car. If by no audio you mean no sound, that could be a lot of things, you might want to check your speakers first.
yes there is no sound and i tried a brand new deck and it still wont even turn on so i am not getting power up there it seems like. I do have 12 volts on one line when i turn the key on but the constant 12 volts wire there is nothing. some one mentioned it could be a bcm?
