heater won't blow hot air
Stroh
2008 - I can't get hot air to blow from the heater. I changed the thermostat. I've checked the hoses to see if one if one if cold, however both feel warm so don't think there's a clog. Suggestions?
How hot does the car get? Cause I know my 04 won't blow hot air until it reaches half way, also check coolant levels .
Sent from my iPhone
If both heater hoses are warm then there is good flow through the heater core. Your problem is inside the car, check the temp door actuator and knob
