Heat extractors
IAGXP
The heat extractors on my GXP dont do a very good job, is there anyway to make thempull more heat out?
Is the path direct?
Have you studied the areas of heat and the areas of pressure then placed the extractors there?
the main issue is your block and heads are aluminum, robs heat from the combustion chamber.
The GXP heat extractors are blocked. But they can be made functional if you remove the material blacking them.
I don't have a GXP, but are you talking about the "vents" in the quarter panels by the doors?
Yes I am talking about the factory ones
Thank you I will tear into it more next oil change, I need to spend a day on it anyway. Alignment, balance tires, oil change, trans flush, power wash undercarage.......and the list continues
