heads leaking oil
you need a ratchet and a socket set. the rear valve cover is easy enough, 10mm for the bolts. the front you're gonna have to take off the tensioner bracket, which uses one or both of 13mm and 15mm sockets.
allright then ill look for it, get off my case.
oh yeah but thanks, bio 248.
