headlight/fog problem
Status
Not open for further replies.
riceburner
THEY NO WORKIE!!!!
:th_laugh-pointup:
but seriously, i had to jump my car the other night and i was using a 200A jumper box and now my headlights do not work...the turn and side markers work just not the headlights or fogs. i think i may have accidentally fried something when using my jump box?...all the other (tail, stop, turn and side) all work properly just the headlights and fogs?...anyone have any ideas? and do we have fuses anywhere but the main box in the engine bay?
I believe there is fuses in the glovebox on the passenger side. I have not needed to change any before but I think that's where I remember seeing them. Check your owners manual to be sure.
i checked the inside fuse and relay and they look good. relay does not have much on the ohm reading...
Check the fuse with a test light or multi meter, just looking at them is not always good enough and swap the relay with another one from the car that is the same to eliminate that issue. If you flip the light switch on manually does it do anything?
Status
