headers tapping front fan
Grimsin
So installed zzp square poly mounts and now my sdheaders are hitting the fan.... any cheap way to fix this i tore the stock mounts so cant put those back in.. i guess the fans shrouds are bigger on 04-05 impalas
ill take a pic when im done work
i took the heat shield off on the driver side. it was hitting during the install. with it off it clears the fan by inches. but thats a 98 regal.
best o got for a pic, as its not of the clearance.
the pass side shield is still there, just the driver side i pulled off.
My 03 Regal had the SD headers hit the drivers side fan. It was actually resting on it. I let it go for 2 years and never really had an issue until I heard the fan cut in and out when I shut the car off. Pop the hood and look and there are sparks coming from the drivers side fan motor (where the header was hitting).
I ended up having to find a set of '98 fans from a Regal and they gave me an extra inch of clearance. Apparently the 01+ Regals had a larger fan/shroud.
first pic - Stock 03 Fans. 2nd - '98 Fans installed
Same issue on 01 impala. I took shroud off. Header still hits fan, so I put some of that sticky backed aluminum heat wrap stuff on it. Dunno what its called but I love the stuff. Buddy gave it to me when a heat shield fell off my Sienna and the fan was melting. I used it in several places. Wrapped a little around the ect gauge. Stuffed and sealed a hole I drilled above exhaust to run my o2 sensor through. Some other places I can't remember.
Just as the posts above, I also had to remove the fan heat shield off of my 04 Impala LS. Header sits pretty close to the plastic fan, no issues so far. The foil tape is a good idea though, I should try that.
I have the same issue.. Wrapped the headers with header wrap and its hitting the fan.. Dont wanna trim the fan with the die grinder so i probably need to get something in between the fan and the header
wouldnt cause false knock though thats what im worried about..
here are 2 pics of how close it is.
video with my foot on brake giving lltlle gas to show what noise it make on take off.
when i rev the engine and watch the header it doest move so at all but thats just free rev not in gear
so where my header is hitting isnt a shroud but the actually fan motor correct? or is that a cover i cant take off?
This issue is only with SD headers?
I have read its a regal and impala issue, and 04+ gp's
looks like the fan itself is getting hit. time for a pair of 98 fans, or maybe some low profile after market fans. they work better, but are a bit louder.
iirc i had pro comp fans on my last truck, 2, 16's was like 30 bucks. you'll need 2 smaller fans for sure.
ugh i dont want to do that....fak! lol
I have some poly bushings on the way maybe it will pull the motor/headers back away form the fan, if the stock bushings are stock.
if you were to get the after market fans, they plug right in pretty much and mount up easy enough. if they dont plug in all you do is cut and solder the old fans plug on the new fans.
