JJ91284
Most definitely. Egr can be an option. Basically im buying headers and modding them like the above ones, except that the crossover wont have a flex as it doesnt need one, and the downpipe flex is on the straight part, not the slanted as above. I can remove the egr and weld it shut if you need.
Crossover pipe has to have a flex if its using a vband on both sides as this is what allows the pipe to slide in and be pulled tight. If it can't do this then your essentially torquing the manifolds off the head to close the gap. If you don't have a flex in the crossover, the design is flawed as you'd have to have the crossover pipe perfect and thats assuming the SSAC ARE AN EXACT COPY which we all know is not true.
