Nchristopherson
So, I have a summit racing credit card and want to get head studs from summit racing. I found these there and think they will do, given the description, but it doesn't specify the series 2, just that "
Can anyone confirm if this would work on our blocks or not? This really should be posted in the L36 subsection, but I can't imagine there is variance in that regard. Also, if they do not work, has anyone the dimensions of the head studs so I can just individually pick them out from Summit? Thanks!
Notes:
Fits Grand National and T-type cars only.". The only issue is four of the studs are oddballs, that is, it isn't two sets of 8 studs like the kit that ZZP sells. Link: http://www.summitracing.com/parts/arp-123-4003. I have no dimensions to compare to either, so it's a bit tricky.Can anyone confirm if this would work on our blocks or not? This really should be posted in the L36 subsection, but I can't imagine there is variance in that regard. Also, if they do not work, has anyone the dimensions of the head studs so I can just individually pick them out from Summit? Thanks!
