TheYanz
I've had my replacement housings since I bought them off eBay in early 2008. They still look awesome. I have used the Meguiar's Ultimate Compound on them every 3-6 months lately. I work it in real good with just a nice, soft microfiber cloth. REALLY work it in. Then just find a clean area of the cloth & rub all of it off so it's nice & clean. Works very well for me. I do the same with my stock tailights, they shine like crazy & look freaking awesome. Don't recall the brand or seller I got the housings from but they've held up very well. At the time, they were around $100. Keep in mind that was 6+ years ago. Sh1t's cheaper now.
I like the retro fit pics ^^^. Looks really nice & clean.
About the aiming of the headlights... I owned my GTP for probably 8 years before I found the actual adjustment screws for adjusting the headlights. It's not mentioned in the GM manual that came with the car I don't think. You need one of those $5-$10 star bit socket sets to adjust them. There's a weird star-shaped screw sticking somewhere out of the top of each headlight. That's what you have to play with to adjust the height up or down. Just an FYI for anyone out there.
Look up the general procedure for aiming headlights online. IIRC, you have to park like 10-20 feet away from a garage or wall (COMPLETELY FLAT SURFACE). Then you have to kinda make a straight line from EACH bulb to the wall & mark it off with tape for each one. Then you wanna measure up from the floor about 4 feet. That's where the top of the light output should hit. They also said to horizontally aim your driver's side one slightly to the right of where it should be so as to be more courteous to oncoming drivers on tight 2-way roads. Makes sense. There's another adjustment screw somewhere in there for the side-to-side action.
