Scottydoggs
Killa Bee
ok. let try bleeding the master then, if it got low good chance it sucked air into it.
find a wrench that fits the lines to the side of the master, then take a rag and wrap the wrench and nut, cause some fluid is gonna leak out.
you need a pedal pusher guy for this. he pumps the pedal 3 to 5 times till its as firm as it will get, he holds the pedal down, you crack the line nut ( do the back one first) his foot hits the floor, he holds it to the floor till you make the line nut snug again, then tell him to pump the brakes again, tell him hold em, you crack the nut again. if its got air, you'll hear the air blow out, repeat till its just fluid coming out.
then do the other line. if all goes well the pedal is better but not perfect, so now you go bleed the calipers, start with the right rear, rear left side, then the pass front then the d/s front wheel.
with a friend you can bleed the calipers the same way, he pumps the pedal, holds it then you crack the bleeder, he holds the pedal to the floor till you make the bleeder tight then he pumps it up again. 3 to 5 times per caliper should be good.
KEEP A GOOD EYE ON THE MASTER, DO NOT LET IT GO DRY. you see it hit 1/2 full, fill it.
