Mike Kopstain
Your supercharger isn't going out. If you had full boost and then all of the sudden had half boost, you knocked a vacuum line off somewhere or damaged the bypass valve by accident. I've never one of these superchargers fail and immediately output less boost. If anything, they wear over time and probably lose a nominal amount of output. A "failing" blower would be one that is making loud bearing noises and even that blower would still make full boost.Im at work. I just had the service manager read the SES code (he use t work at a GM dealership). It came up with P404 and P1404 codes. He said the codes were saying its a bad EGR valve. Is this true? He also said as far as the boost issue, the blower is going out. What do you guys think? Could the lack of boost be affected by a bad egr valve? I just looked on craigslist and I called John's auto parts (a junk yard here in minnesota) and a used supercharger is $200-$300. The egr valve is $150. I really hate those kind of suprises. I would really like your guys' feedback. You guys seem to know these cars best. Thanks.
